That black insulator is an add-on from the past; get rid of it & fill in the hole. I would suggest not using the clamp-on battery terminals; get the solder type from NAPA for more positive results. The clamp-ons are at best a temporary fix because the wire is exposed & corrosion will attack rapidly.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
