Re: Super M Won't Start
Posted by Dave2pa on February 23, 2009 at 10:24:16 from (24.144.229.55):
In Reply to: Super M Won't Start posted by Farmall Ed on February 23, 2009 at 07:29:04:
is it 12 volt ?? if so does it have a resistor ?? if it does trying running a by pass wire to the coil and give coil a jolt of FULL 12 volts ,, Dont hook it permanently but while you crank it, bump the wire on the battery and see if it Fires ,I mounted starter switch on mine and while cranking just bump the switch ,,it works good on anything with a resistor .
