Re: W9 hydraulic valve mounting
Posted by glennster on February 23, 2009 at 17:24:59 from (68.60.242.156):
In Reply to: W9 hydraulic valve mounting posted by Chris NW Ind on February 23, 2009 at 07:53:39:
in guy fays book on the letter series, there is a photo of a 9 with the hydraulic valve mounted directly below where yours is a t, on the deck against the fender, about even with your couplers. i picked up a live pump asem from joe in il a while back off his wd-9, that valve mounts on the right side of the tractor.
