Re: UD-9
Posted by Bob M on February 23, 2009 at 17:35:35 from (74.74.133.120):
In Reply to: UD-9 posted by IHStandardMan on February 23, 2009 at 15:12:21:
Well the U9 and UD9 engines are essentially identical to the engines used in the W9, WD9, I9 and ID9 wheel tractors; also in the T9 and TD9 crawlers.
Also they U9/UD9 engines are similar to the M/MD and T6/TD6 tractor engines, just larger.
Info on any of the above will cover just about everything about a U9/UD9 engine except the power take off clutch.
