Re: Super A Numbers
Posted by Hugh MacKay on February 23, 2009 at 17:50:29 from (209.226.106.164):
In Reply to: Super A Numbers posted by wendle on February 23, 2009 at 16:42:08:
wendle: The engine number you've given, 354898 R1 is the block part number. That is the right block parts number for tractor serial number 317310. All Super A after serial number 310300 used that block.
The engine serial number is just below No.1 spark plug on a machined flat surface, about 1/4" to 3/8" high digits It should say FAAM then a 6 digit number. It wont be same as tractor serial number, probably 500 higher.
