1 - Does the starter still spin the engine as fast as when the tractor started easily? If not find and correct the cause. Look for a failing starter, bad cable connection, a weak or undersized battery, etc. (Just because a battery's the biggest TSC sells doesn't mean it's big enough to start your tractor!).
2 - Are you getting lots of white out the exhaust while cranking? If not it's an injection system problem. However if you see lots of dense white exhaust the problem is low compression. Time for a ring and/or valve job.
