Re: 7130 low hyd flow
Posted by 756puller on February 24, 2009 at 13:07:10 from (65.167.248.82):
In Reply to: Re: 7130 low hyd flow posted by JJK on February 24, 2009 at 13:02:12:
the high pressure standby is set at roughly 2800 psi, i have the brakes steering and 3 pionnt caped off right now and nothing hass changed yet, i pulled all 4 remotes at once, 2 3 and 4 work the same way but when i pull on 1 the syetsm just dies off
