Re: Which motor oil GRADE is best for Farmall H
Posted by Hoss in Me on February 24, 2009 at 15:30:33 from (69.131.127.33):
In Reply to: Which motor oil GRADE is best for Farmall H posted by Brad in WI on February 24, 2009 at 14:22:34:
Id run 15-40 Rotella in it.Very good severe duty oil.I run it in all my tractors car and both trucks Hoss
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
