Posted by JJK on February 24, 2009 at 16:18:09 from (166.216.128.8):
In Reply to: 7130 low hyd flow posted by 756puller on February 23, 2009 at 16:46:36:
#1 remote has priority and the other remotes will drop off until #1 is satisfied. Slow #1 down and the others should pick up. I assume that all the flow controls on the valves are free to turn and are turned to the max position. Did you have the flow control spools apart? Make sure the springs under the spool aren't broke and the little roll pin for turning the spool haven't broke off and the ends started floating in the system somewhere and that ALL the orings are good. I'd start on #1 first or just go through the whole valve stack and be done with it. It's your overhaul! Keep me posted if you could please.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
