Re: 300 Hydraulic question
Posted by IaGary on February 25, 2009 at 04:42:50 from (207.177.17.200):
In Reply to: 300 Hydraulic question posted by KenB_Texas on February 24, 2009 at 19:31:39:
If you hook both 3pt cylinder hoses, to the two ports on the back, that are hooked to one valve, it will not work.
Hooked that way when you pull the lever one cylinder will lift. When the lever is pushed the other way the other cylinder will lift.
Tee them together and hook to one side of the valve as Janicholson said.
