Posted by ScottyHOMEy on February 25, 2009 at 07:07:10 from (70.105.240.166):
In Reply to: broken bolt posted by Mark W. on February 25, 2009 at 05:44:01:
Mark, if it's one of the bolts that hold the shaft housing to the transmission case, those should be 7/16" NC.
Not sure how you're equipped, but there's about a half a dozen basic ways of attacking that bolt.
If you can weld, there's a lot of success to be had welding a good nut to the stump of the bolt and using the nut to turn it out. The heating and cooling involved with the welding will help to loosen it, too.
If you're not equipped to do that and can't find anybody to help you do it, then you'll have to go at it by drilling to some extent. Best general advice I can offer there is to get hold of some left-twist drill bits. A good hardware will have a small set that will have sizes enough to work. That left twist with the heat generated from drilling will sometimes break them loose, so use a left twist bit for any drilling you do. Whether you wind up drilling it out completely, or just enough for an EZ Out, I'd suggest starting with smaller bits and working your way up. The repeated heat and CCW torque may just break it loose in the process. In any event, do everything you can to keep your bit centered and running straight in. If you can do that, a 3/8" bit is about the largest you can go without drilling out the female thread along with it.
You'll get a lot of opinions about E-Z Outs -- some brands are better than others, some folks don't like any of them and I can't really blame them. They're VERY hard and if you break one of them off in the hole, you'll have a brand new problem.
I've had good luck with a gadget called Drill-Out. Comes in a set, mine were from CarQuest but Sears and other sell them. Basically it's a threaded mandrel with a drill tip on it that resembles a self-tapping screw -- left hand twist, of course. With your drill in reverse, the tip cuts the pilot hole down into the bolt. When it reaches a good depth, there is a second, tapered piece that threads down over the mandrel and bites the edges of the hole made by the drill tip. As it goes further, ridges on the taper fill and bite the edges of the hole. Some bolts will pop out as soon as the torque hits it with the outer piece, but it also has a hex head on the outer piece so that you an take your drill off of it and apply a wrench. I like them because they work, they're easy,and they're much less apt to break than an E-Z Out.
Anything you do should involve heat before you actually try to get it out. Try heating it with a regular handheld torch, propane is alright but Mapp gas is better/hotter. Heat it up well all around it once and let it cool. Heat it a second time focusing your heat on the bolt itself until it starts to turn red-to-yellow on the edges and let it cool. As that starts to cool, try applying a little of your favorite penetrant (PBBlaster, Liquid Wrench, MMO . . .). That does two things and works especially well if you still have a little thread or neck of the bolt protruding to help hold some of the magic formula in place. Start applying it while it will still sizzle and keep applying. It's cooling things a little faster and the shock will help to break up the corrosion that is holding the bolt fast, and as the corrosion crumbles/fractures and the whole thing cools, it will draw the penetrant into any gap. At that point let it cool down completely. Then just before trying your E-Z Out, Drill-Out or whatever, apply more heat to the tranny, keeping a little distance away from the bolt, the idea being to expand the outer part of the thread without putting so much heat to the bolt that it expands, too.
I've gone on long enough. All else fails a HeliCoil will fix her right up, but that's another discussion.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
