Re: Light switch problems
Posted by Red Dave on February 25, 2009 at 11:26:29 from (66.216.141.163):
In Reply to: Light switch problems posted by neblinc on February 25, 2009 at 11:17:52:
If you are not getting full charging amps when you ground the generator field, you have a bad generator. Grounding the field bypasses cut-outs, regulators, field resistors, all of it. It just puts the generator at full output.
