Re: Light switch problems
Posted by glennster on February 25, 2009 at 12:43:38 from (76.223.245.56):
In Reply to: Light switch problems posted by neblinc on February 25, 2009 at 11:17:52:
randy, did you try the motor test on the genny?
i had a problem getting my h to charge, janicholson and john t heped on that one, turns out the insulation under the field post on the genny. when you tightend the terminals down with the wires on them it would short out. bench tested fine, and motor tested fine, but when all hooked up, wouldnt charge.
