Hi Rockin, you can check if it is the lift cylinder is leaking or the lift control valve. With an implement on the 3pt hitch close the valve at the front right side of the seat then turn the tractor off. If the 3pt hitch still goes down then the problem is most likely leaky lift cylinder "O" rings. Be sure to open the valve before starting the tractor again. If the 3pt stays up the problem is else where. If there is air in the system usually you hear the hydraulic pump whining and the hydraulic lines vibrating.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
