Posted by Bob M on February 26, 2009 at 07:34:28 from (151.190.254.108):
In Reply to: 756 alt posted by 4 bottem on February 26, 2009 at 05:36:48:
Presuming your 756 currently has a Delco alternator, swapping it for a Delco 10SI (internally regulated) alternator is straightforward.
Mechanically it’s a direct swap – the 10SI will fit the existing bracket and tension arm. And you can swap the pulley/fan from the old alternator if the pulley on the new one doesn’t match.
For the wiring:
1 – Find the wire at the old regulator that goes hot when you turn on the ignition. Connect this wire to the #1 aux terminal on the new alternator.
2 – At the alternator, connect the #2 terminal to the BAT terminal.
3 – Tape off the remaining wires at the regulator – they are longer used.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
