Re: 756 alt
Posted by Gary Hutchinson on February 26, 2009 at 10:34:01 from (192.236.20.254):
In Reply to: 756 alt posted by 4 bottem on February 26, 2009 at 05:36:48:
When I bought my Farmall 560 it had an external
voltage regulator wired to the alternator. It
was an old-style mechanical type and was not wired in properly. I was able to find a pin-for-
pin direct replacement solid-state regulator at a local car parts place and that, combined with
being wired in correctly solved all my issues. I
don't remember what it cost, but I doubt I paid
more than $50.00. If you want to persue that,
take the time to have a garage check the alternator output to make sure it isn't shot. If
the alternator is bad, I'd go with a rebuilt that has the regulator internal or do the single-wire thing. I don't know from personal experience
but have been told than until you rev the engine
and get some "tickle" to the one-wire, it doesn't
put out much. If that's true I'd rather go with a conventional alt/reg and have good output as soon as the engine starts.
