Re: Plows for Farmall M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by john d on April 07, 2000 at 14:06:58 from (206.141.74.34):
In Reply to: Plows for Farmall M posted by Pat on April 06, 2000 at 06:12:26:
If the M is healthy, it will easily handle a 3-14 trailing plow.
If the M has been overhauled at some point in its life and given some oversize sleeves/pistons, improved governor, etc, it will do even more. We've pulled a 3-16 mounted JD plow with the 3pt hitch on ours, and it goes anywhere in 2nd, most places in 3rd. Used to occasionally hitch a Moline 4-14 trailing plow on it, and it would handle it quite well, most places in 3rd. Traction may limit you more than HP unless you have some good tires and weights. A lot of people assume these old M tractors put out the HP that the factory specs on them say....and in many cases, that's way UNDER what they now produce.
Post A Followup
: Re: Re: Plows for Farmall M
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
