Posted by Gary Hutchinson on February 26, 2009 at 13:53:46 from (192.236.20.254):
In Reply to: Re: 756 alt posted by bc on February 26, 2009 at 11:50:16:
For my money, I'd go with an ammeter no matter what kind of alt/reg combo you are using. It gives you more information about what is going on in your system. All a voltmeter does is tell you that you are building enough voltage that you should be charging. The ammeter actually will tell you that plus whether there is more juice going into the battery (charging), or more coming out (discharging). If the meter shows the direction is charging, then you know your alt/reg output is enough to run your ignition, accessories, etc. and still have enough left over to charge the battery. Normal operation is that when you first start, you'll see 10-15 amps of current in the charge direction and then slowly fall off to just a couple of amps after you've run for awhile.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
