Posted by CNKS on February 26, 2009 at 18:18:51 from (216.144.104.128):
In Reply to: fluids posted by Patrick Millwood on February 26, 2009 at 17:51:52:
15W-40 in the engine, 90, 80W-90, 85W-140, 140, etc in the transmission/rear end, Hytran or equivalent in the hydraulics. If the chassis serial is 356001 or above it is a Super A-1, likely worth a little more than a Super A in the same condition. Would suggest you buy an Operators manual, you will find maintenance info you wouldn't know otherwise.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
