Loosen the clamp bolt and slide the the whole works back off of the front shaft. Clean the joint up and you will see the snap rings that hold the caps in place in the ears of the two halves of the joint. Remove the snap rings. You will need a large C clamp and two sockets, one to push against one of the cap ends (this one should be smaller than the OD of the cap) and another that is just large enough for the cap on the opposite end to pass inside of it as you press it out. Email me your phone # and I'll give you a call. It is much easier to describe the rest of the process.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
