Re: points and pugs
Posted by Karl Hamson on February 26, 2009 at 19:49:39 from (24.64.223.204):
In Reply to: points and pugs posted by Farmer(Ga) on February 26, 2009 at 19:44:12:
Sounds to me like the problem is fuel starvation. I would eliminate that possibility before going into ignition issues. Make sure that the screen in the sediment bowl is clean and you get a good flow out of the gas line after disconnecting it from the carburetor. There is a filter in the fitting where the fuel line attaches to the carburetor and that should be checked as well.
