Re: Stuck engine Farmall H
Posted by John A. on February 26, 2009 at 21:27:50 from (216.141.24.7):
In Reply to: Stuck engine Farmall H posted by Scott Simonton on February 26, 2009 at 12:17:01:
Scott, ? Do you want this engine loose in short order??? Then follow my instructions. the engine will be loose over the weekend!!!
1 Remove all tin work, gas tank, intake/exhaust, Valve cover, & Head, Pan. Remove and # Rod Caps.
2 roll tractor outside and double check to make sure there are no combustables near and no tree limbs close.
Get a gallon of gas and 2 or 3 gallons of Diesel. a couple of 2x4 blocks and a good 4 or 5 lb machinist hammer.
3 Make a pot of coffee!
4 Now start ( 1 cylinder @ a time) with the cylinder that has the most Volume! pour in, to almost full with Diesel, add a splash of gas set the fuel mixture on fire.
Pour a cup of coffee and let the mixture burn itself out. Now drive the piston out from the bottom.
5 Repeat with the cylinder that now has the most volume and repeat the #4 step. Note... As the volume decreases and the amt of rust increases you may need to repeat step 4, 2 or 3 or more time to get the engine freed up!
Note 1, the Cup of Coffee step... is very inportant not to rush the burn and heat build up in the cylinder, it is what breaks up the rust that has seized up that engine in the first place
Note 2, Cold Beer, can be substituted for the Coffee. BUT it has to be Super Cold though, Again not to rush the burn! LOL
You get the idea, just be very careful with the gas and diesel & fire. Don't burn your barn or house down.
Later
John A.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
