Re: Farmall H clutch
Posted by jonathan mirgon on February 27, 2009 at 08:26:28 from (4.225.99.45):
In Reply to: Farmall H clutch posted by dan harjes on February 27, 2009 at 07:53:58:
Although I am not overly familiar with the way the "H" is setup. It sounds like you do not have enough travel on the control rod that operates the throw out bearing, And in turn the pressure plate is not being pushed in far enough to totaly disengage the clutch. You should have an adjustable rod on the linkage coming off of your clutch pedal. The linkage needs to be adjusted to take some of the free play out of the pedal and apply it onto the pressure plate. I am sure if I am incorrect one of the "H" veterns will correct me. Good luck.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
