Posted by rustyfarmall on February 27, 2009 at 11:06:51 from (209.152.78.199):
In Reply to: Farmall H clutch posted by WildWill on February 27, 2009 at 07:53:58:
dan harjes said: (quoted from post at 10:10:46 02/27/09) Thanks, I should note that the rod pushes the lever forward so that it nearly strikes the bellhousing and in fact I needed to shim the pin outward as it did strick the tractor.
Does the swing arm into the transmission adjust too or is something inside not right?
Dan
Something is not right. I think you need to remove the inspection cover from under the tractor, and maybe even drop the belly pump, stick your head up in there and have a look. You DO NOT need to split the tractor in order to replace ANY or ALL of the clutch components.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
