Re: A414 lift stuck in raised position
Posted by BCNewf on February 27, 2009 at 12:50:28 from (64.253.156.46):
In Reply to: A414 lift stuck in raised position posted by AussieA414 on February 27, 2009 at 04:16:37:
Check the isolator valve (the knob under your right leg on the front of the hydraulic housing). It sometimes gets turned in from rubbing on your leg. If it is in, it will isolate the cylinder from the valve keeping the three point up.
This might not be the problem, but it would be the first thing I checked before digging into the valve.
