Re: Farmall H Hydraulic pump seal
Posted by Janicholson on February 27, 2009 at 19:28:48 from (66.173.50.80):
In Reply to: Farmall H Hydraulic pump seal posted by David G on February 27, 2009 at 19:06:24:
Did you remove the drive hub? It must come off. Lefty Loosy. A heavy square bar (tempered) will make it turn, JimN
