Posted by Jim Becker on February 28, 2009 at 07:16:09 from (173.57.160.166):
In Reply to: Noisy transmission posted by Mike Franks on February 27, 2009 at 21:31:23:
In neutral, the only thing turning is the input shaft with the drive gears. Any noise in neutral just about has to be either the front or rear input shaft bearing. That shaft comes out the front of the transmission, requires splitting the tractor betweeen the transmission and bell housing.
If you do open it up, be sure to put the oil seal retainer back the right way. Put it on backwards and the shaft can move forward and give you a new batch of trouble.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
