Re: Oil seals in axle
Posted by pete 23 on February 28, 2009 at 07:48:25 from (173.87.1.12):
In Reply to: Oil seals in axle posted by IH Country Boy on February 27, 2009 at 19:53:00:
The felt is your call, the original seals did not have the outer dirt lip therefore they used the felt to keep dirt out of seal. New seals normally have the double lip, outer one to keep dirt out. If you crowd the new seal up against a felt you will effectively render that outer lip non existent. Will work fine eiether way.
