Re: 1086 Acceptable Engine blow by
Posted by bemhoff on February 28, 2009 at 08:57:49 from (208.19.154.2):
In Reply to: Re: 1086 Acceptable Engine blow by posted by Allan In NE on February 28, 2009 at 08:26:24:
Yep, you are probably correct and it may be a meaningless walk. But if i have this data I can prove my point with out having to spend the money on a rebuild and hope that it fixes the problem. I don't have years of experience like a lot of you guys out there that can walk up and stick their hand under the breather tube and judge if there is excessive blowby or not. Never done that. I just thought i would ask to see if anyone knew then it would be a no brainer. Thanks again. Bemhoff
