Re: left rear tire locked up while in gear
Posted by Nebraska Cowman on February 28, 2009 at 12:24:45 from (66.252.120.75):
In Reply to: left rear tire locked up while in gear posted by mike mcmurray on February 28, 2009 at 10:43:57:
You just need a bigger car. No, put the tractor in HIGH GEAR or at least 4th. that will lower the resitance to get the engine turning over. It is natural for one wheel to slide or even turn backwards as ground traction is less than the resistance of the engine. If you had no diferential both wheels would slide.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
