Re: left rear tire locked up while in gear
Posted by SDE on February 28, 2009 at 15:54:37 from (98.125.63.7):
In Reply to: left rear tire locked up while in gear posted by mike mcmurray on February 28, 2009 at 10:43:57:
I hope that you do not literally "pop" the clutch. Let the pedal out as if the engine was running. If it slides a tire, you need a higher gear or a better surface, like dry pavement.
Can you jack the rear end up so that both tires are off the ground? If so, put it in high gear, take the spark plugs out and try to rock one of the rear tires. Naturally, you will need to have the tractor resting up against something stable enough to keep the tractor from moving.
Safety first. Don't use excess force. After all if there is something jammed between a bull gear and the housing, you could still break something. Although if it did not break using the Jeep, you should not be able to break it.
If they both can be moved, you may not have anything stuck.
SDE
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
