Re: 1456 clutch
Posted by pete 23 on February 28, 2009 at 16:18:38 from (173.87.1.12):
In Reply to: 1456 clutch posted by joe 1971 on February 28, 2009 at 13:50:21:
The booster should not move upon starting engine. Even if adjusted wrong it would only move a little. Back adjustments off on both ends until linkage is free , start engine. If any movement the valve in booster is stuck or assembled incorectly. Proper adjustment starts at pedal side. Take up slack so linkage is just touching activating piston, this should give you about maybe half inch pedal movement of valve before output end starts to move. Then adjust other end to get about one eight inch clearance on release bearing to fingers. Clear as mud, right, could show you in a minute but not good at describing procedure.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
