Re: 1086 Acceptable Engine blow by
Posted by Owen Aaland on February 28, 2009 at 19:31:11 from (65.165.246.54):
In Reply to: 1086 Acceptable Engine blow by posted by bemhoff on February 28, 2009 at 07:17:48:
The either injection system is designed to be used only while the engine is already cranking over. If you have good cranking speed and then give it a shot of either it should fire up without a lot of knocking.
When cranking, before it starts, are you getting smoke out of the exhaust? When you replaced the fuel injectors you most likely increased the opening pressures. If the pump is getting weak you may not be getting enough pressure to open the nozzles at cranking speed. This is not an unusual problem after servicing the injectors.
