Posted by pete 23 on February 28, 2009 at 19:57:02 from (173.87.1.12):
In Reply to: 1206 won't move posted by D.Greig on February 28, 2009 at 10:39:44:
Did you run engine with plug removed. Normally if rear pump works as you indicated enough fluid is able to get through filter for front pump to operate also, however it has a harder job of pulling the oil so you might change filter and or add about 5 gallons extra oil to cover suction tubes. Once your pump runs dry for a while it may take reving the engine to get it to prime up with the plug removed. Moisture in oil will cause ice crystals to slow flow through filter but I still think it will prime up .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
