Hi, power beyond adapters is the IH way to do it but very $$$. The other way to do it is to tap into the pressure line that comes out of the remote control valve and goes to the depth control model under the seat. Unfortunately to access this 90 degree fitting on top of the remote control valve, you have to lift off the deck that the seat is connected to. The tube that you remove is called the "auxillary valve return tube", it is sort of an L shaped tube that goes from a 90 degree elbow on top of the remote control valve to the drapth control under the seat. So the in line to your new vlave unit would connected to the 90 elbow and out to the draft control port. Some installations cap off the drapth control port and put the return into the hydraulic drian plug under the right axle housing.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
