The adjustment screws should be clearly visible. Apparently the previous owner found a clutch that "fit". If so it is not the correct one. Have you tried adjusting the linkage between the pedal and clutch shaft? Also in some older clutches there are bolts that compress the pressure plate until the clutch is installed, then they are supposed to be removed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
