Re: H Problem
Posted by dan harjes on March 01, 2009 at 21:22:23 from (75.253.114.190):
In Reply to: H Problem posted by farmallboy1994 on March 01, 2009 at 21:11:31:
Two things happened to me with mine and a friends H. His did nearly the same thing but then reved way high...in placeing the carb back on, somehow he turned the "governor throttle shaft" and it was stuck making no power and then when he adjusted the carb to fix that, the motor reved too high popping and what a scare. Turned the governor shaft and works great. The other thing, I added old gas and found it was realy old and probably water in it. Killed, started up and popped and no power and killed again. Drained, new gas on mine and bingo...works great. Dan
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
