If this tractor was running and then parked, it is possible that it was parked for a clutch problem. The levers should be about parallel with the friction surface of the flywheel when installed. All three should be the same. As wear occurs the levers will start to move back farther. If they are tilted in, especially if they are not even, it is possible that the lining came loose on the disc and doubled up. On a Super M it is possible to remove the disc from the clutch but you cannot get the pressure plate assembly out. It is probably time to split the tractor to remove and inspect the clutch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
