Re: Super A Loader Hydraulics Question
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dennis on April 07, 2000 at 20:44:06 from (205.188.193.182):
In Reply to: Super A Loader Hydraulics Question posted by DaveT on April 05, 2000 at 13:07:24:
For twoway power you need two way cylinders. You can tell these in that they have fittings on both ends. You will need a 2 spool valve( this is for 2 levers. it should have but 1 inlet port and 4 outlets. you simply connect your pump to the inlet port. it will also have an outlet port. this goes to the touch control resevoir. you willnot need a bigger resevoir. The cylinders have oil on both sides of the piston. email for better explanation. your pump is fine.
Post A Followup
: Re: Re: Super A Loader Hydraulics Question
