Re: Joint in steering shaft of H part ll
Posted by Janicholson on March 02, 2009 at 15:55:50 from (199.17.6.128):
In Reply to: Joint in steering shaft of H part ll posted by Paul Shuler on March 02, 2009 at 15:25:45:
A pair of 3/4" thick plates with 3/4 inch holes about 3 inches apart And some grade 5 fine thread bolts can take the place of the C clamp.
The pressure will be about 3 times what you can generate with the clamp. Other than that, you are thinking correctly.
If it were on the bench, one half would be placed at rest on the top of the open vice jaws, supporting one half of the joint, while the other side was whacked with a socket held in a pair of pliers to knock the cap uut of one end, then turned over and whacked the other way to shove the other cap out. Then the remainder would be put in the vice with the bare trunions (inner bearing stubs) resting on the vice and the other half whacked apart. It is a reality trip for sure. JimN
