Re: H spraying oil
Posted by mattofvinings on March 02, 2009 at 16:02:17 from (67.142.161.28):
In Reply to: H spraying oil posted by hvacpro85 on March 02, 2009 at 16:03:32:
That's one possibility that a compression test would probably answer.
Another possibility is there's some sort of blockage in the head and oil is running down from the valve spring/rocker arm area thru the valve guide(s) into the exhaust. A crack in the head leading to the same result is also a possibility.
Last thing to check is that the engine oil has not been grossly overfilled.
This post was edited by mattofvinings at 16:03:16 03/02/09.
