Re: 986 tramission more questions
Posted by DMont on March 02, 2009 at 17:55:56 from (72.9.65.174):
In Reply to: 986 tramission more questions posted by chris meredith on March 02, 2009 at 16:03:38:
The park pawl engages the reverse driven gear to hold the tractor when stopped. You will need to remove the HiLo shifter cover to replace the park pawl.
If the Reverse driven gear has teeth missing you probably will find some of them in the bottom of the case where the rear hyd pump is located, which is just in front of the left rear axle. If that is the case you will need to split the trct behind the speed trans. Pull the rockshaft cover, axle hsgs, brakes, ring gear and then the pinion shaft. The reverse driven gear is located on the pinion shaft. Some might say just a walk in the park, but have plenty of room because there will be parts everywhere.
