chris meredith said: (quoted from post at 17:03:38 03/02/09) so early you all told me that we all was thought it was a bork reverse gear if it is a revers gear woudl the parks till be working because the park is good suposely any wya my question is can you inspect the gears with removing the side long plate behind the fuel tank can that determine the problem if so does the torque haft to coem out to ge that shaft out thanks so much for any and all replyes
The park lock will still work with some teeth broken off the reverse driven gear. The park lock pawl swings down and in to engage two teeth on the gear. The two teeth used are not next to each other on the gear so it would be unusual for the pawl to come down where was two broken teeth. If you get a clicking noise in reverse, and only in reverse, that gear is going to be the problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
