Re: 1959 IH 460 diesel questions
Posted by pete 23 on March 02, 2009 at 19:21:05 from (173.87.1.12):
In Reply to: 1959 IH 460 diesel questions posted by GoJDpuller on March 02, 2009 at 18:00:38:
I'll address clearing up the exhaust after it is running and warmed up. These engines have a load advance system on the injection pump. What it does is advance the timing at all no load conditions , high speed or low speed and then it retards the timing as you come under a load. It is easy to adjust but you need to put a window on the pump in place of the timing cover. You would need someone experienced in doing adjustment or a manual showing how. Kind of hard to explain on here. Best way is on a dynamometer but have adjusted a jillion by observing advance mechanism when quickly reving engine. Of course you could have it done on a test bench also. Static timing is 3 degrees BTDC. Fuel pressure of course needs to be up to specs when doing adjustment also. They will sound awful if advance is not working and timed correctly.
