Re: 240 utility questions
Posted by K-Mo on March 03, 2009 at 04:35:07 from (65.169.189.2):
In Reply to: Re: 240 utility questions posted by gonecountry on March 02, 2009 at 20:31:27:
Although the 240 is a nice little tractor, it is short on hydraulics and no IPTO. As IHfan said the feedback control cable for the hitch is a problem area. However later models use a mechanical feedback instead of the cable. If it has the mechanical feedback, that would be a plus.
The feedback is used to stop the hitch at a lever position. If this does not function, the hitch will move to a limit and maintain pressure on the system. Continous system pressure will cause overheating and pump seal failure.
K-Mo
