Re: To convert or not to convert
Posted by Bob M on March 03, 2009 at 04:43:37 from (151.190.254.108):
In Reply to: To convert or not to convert posted by ADLM on March 02, 2009 at 23:07:39:
Whether or not to convert to 12 volts? Answer is “it depends”.
If your tractor is going to be a daily worker then by all means convert it 12 volts and install an alternator. This uses the least expensive parts, requires the least maintenance, provides reliable starting in the coldest weather, and permits the use of 12 volt halogen lights (MUCH brighter than OEM volt lights!).
However if you are simply restoring the tractor I’d recommend buying a rebuilt 6 volt generator, a new regulator and a new wiring harness and bringing the electrical system back to original. (Keep in mind a properly maintained 6 volt system will start your tractor reliably and will give excellent service for show/parade and other occasional use.)
Your total labor for either option will be about the same.
Bottom line: There’s no “right” answer(!)
