Posted by Janicholson on March 03, 2009 at 06:33:38 from (199.17.6.29):
In Reply to: Farmall H Knock posted by Jadon Pike on March 03, 2009 at 00:47:20:
I would pull the belly pump (or maybe it is still out) and start by checking the reconstruction of the clutch shaft joint. if either not tight, or reassembled incorrectly it makes that noise. If it looks good (and is) I would then use a pry bar on the perimeter of the Flywheel to see if it is loose Tweek both axially and radially as well as forward and back on a ring gear tooth in the direction of rotation. If it still knocks, I would pull the clutch PP and retighten the Flywheel. Best of luck. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
