Re: how to fix a varible speed throttle lever
Posted by Janicholson on March 03, 2009 at 07:17:56 from (199.17.6.29):
In Reply to: how to fix a varible speed throttle lever posted by sco 656 on March 03, 2009 at 07:03:38:
caseih.com search for parts and put in your tractor. the throttle linkage likely has a spring that is rusted thin or broken. Replacement will fix it, A friction disk can be made from belting or shoe leather to replace a worn disk. Good luck. JimN
