Re: 1959 IH 460 diesel questions
Posted by pete 23 on March 03, 2009 at 07:19:01 from (173.87.1.12):
In Reply to: 1959 IH 460 diesel questions posted by GoJDpuller on March 02, 2009 at 18:00:38:
As far as a pos, well, I always said in my later years that I was going to buy one of these 460 diesel's just to get even with it and fix it up my way. Haven't done that yet,probably won't. There is a saying around here that if you walk around them with an ice cream cone they won't start on a hot summer day. If you have one with the engine up to specs, late style micro injection nozzles, improved inj pump etc, they do run pretty decent. They never had a good starter though, no matter how big cables and batterys you have. The later 282 like in a 656 will whip right over and take off, and seeing as how the two clutch housings and the flywheel are near identical on the two, I wanted to experiment with adapting that starter to the 460 but, like I said , probably never will. I am sure others have a lot of ideas on this.
