Re: IH 424 clutch
Posted by IH2444 on March 03, 2009 at 10:18:28 from (74.234.157.81):
In Reply to: IH 424 clutch posted by MTB on March 03, 2009 at 10:06:14:
If your tractor is like a 444 and I think it is then htere is an inspection plate under the tranny. Remove it and you can see PT0 clutch disk adjustment bolts around the clutch rim 3 I think.
I had the same problem with my 444 PTO.
I adjusted the bolts to about an .080 clearance if I remember correctly and everything worked fine after that. If the gap is too wide your PTO clutch disk will not release.
